SDWAN scalability matrix
agredanoen
Does anybody know where i could find a Scalability matrix (  Max throughput, tunnels, WAN/LAN ports ..  ) for SDWAN edge devices?
Hope you can help
Thanks in advance
Best Regards
Enrique Agredano
2 Accepted Solutions
daniel.dib
Level 7
Level 7
Unfortunately, I haven't seen a document summarizing all of that information in one place. For throughput, the license you can get for a device is tied to what capabilities it has. It's not possible to get a 1 Gbit/s license for an ISR 1100 for example.
Do you have any more specific questions?
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Check in Sales connect if you are a partner or reach out to your Cisco SE. I have seen a document few weeks ago but it's confidential doc.
Srikanth
daniel.dib
Level 7
Level 7
Daniel Dib
CCIE #37149
CCDE #20160011
Srikanth
You can check out Cisco Live presentations such as ‘BRKARC-1006’, however you’ll need to work with your Cisco SME for this.
Throughput can vary per platform depending on what features you enable QOS, ZBF DPI, NAT,FNF etc…
You’ll also need to consider BFD tunnel scale, I believe the ENCS 5412 supports a maximum of 100.
Regards, JW
