SDWAN Tunnel interface
Ariyarathna
Hi friends,
can you please help me to understand the Tunnel concept use in the SDWAN.
1.What is the tunnel source address ? (is it physical IP address bound with the tunnel)
2.What  is the tunnel IP address ? (is it the system IP)
3.WAN-Edge device use same tunnel interface for control connection (DTLS/TLS) and Data plane (IPsec). How Router undestand which traffic should encapsulate using  DTLS and which traffic should encapsulate using IPsec ?
4.In DTLS connection will the wan-Edge device encapsulate encrypted packet with new IP header ?
Thank you verymuch for your support
svemulap@cisco.com
Hi Ariyarahna -
For
Yes. It is the physical IP Address bound to the (d)TLS tunnel
No. See above. System-IP is not used for routing in SD-WAN. It is similar to Router-ID on a regular router, which is the address used to identify the router from which packets are originated.
The System-IP address is used internally as the loopback address of the device in the transport VPN (VPN 0)
When it is talking to Controllers it is (d)TLS and when it is talking site-to-site, it is encapsulated using IPSec.
We use Tunnel Mode. [ It adds a new IP Payload header ]
Check out the Design Guide: https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html
It has a pretty good information on the solution end-to-end
Thank you very much for the reply.Please help me to confirm following understandings.
so ,
in the point 4 , also the controller DTLS connection will use tunnel mode and in this case also New IP header IP address and original IP header IP address is equal to the physical interface IP address.
