Sdwan
a-sheded
we can make combination between cisco 8200 and 8200L as edge Router in the same sdwan solution
balaji.bandi
If i understand correctly in the branch you like to use combination of that router models.
i do not see why not, as long as they are capable of doing, make sure if any interface differerence, change the template on sd-wan when you pushing, like 8200 and 8200L
both are same, only they ship with 4G and 8G and one dont have SSD (may be some feature you looking like thousand eye on Router with browser bot may required SSD - some times) - need to check the documentation.
BB
generic answer is yes. Both 8200 and 8300 new series support SD-WAN and you can mix models in the same SD-WAN overlay.
Just read datasheet for detailed information and for limitations (if any):
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8200-series-edge-platforms/nb-06-cat8200-series-edge-plat-ds-cte-en.html
HTH,
