09-04-2019 06:11 PM - edited 09-04-2019 06:36 PM
Hello All,
We're not able to run speed test in vManage on any of our vEdges, we get error "Device Error: Server unreachable". It never worked.
We're running 18.3 on vSmarts and 17.2.8 on vEdges. I read somewhere that we need to have 18.3 on both ends in order to run speed tests. I haven't found any Cisco documentation on minimum firmware requirements to run speed tests in vManage. I would greatly appreciate if someone could confirm if speed test is not supported on vEdges with firmware 17.2.8.
Thank you,
Hitch.
09-04-2019 10:20 PM
Speed test was added in 18.2.
Note though that you can run iPerf from the CLI. That is basically what speed test does but it does so from the GUI.
09-05-2019 12:30 PM
This document should be helpful to troubleshoot such errors: https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/214662-data-stream-troubleshooting-tools-faq.html
