Transfer CSR1000v smart license AX
mkuma
Could we get the CSR1000v license transferred from one device to another. If yes, will highly appreciate if you could provide with the steps to achieve the same. Thanks
smart licenses are portable i.e you don't need to do special re-hosting as we did/do with PAK.
Enable call-home, enable smart licensing on new router. Of course, you should have smart account and respective license in that account.
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01000.html#con_1014512
HTH,
