Using Portchannel links for TLOC Extension
Kobra09
Hi guys,
Is it possible to use Portchannel links instead of individual links for TLOC extensions on two Cisco 8300s?
Starting from Cisco IOS XE Catalyst SD-WAN Release 17.13.1a and Cisco Catalyst SD-WAN Manager Release 20.13.1, EtherChannels configured on the transport side support the following:
  • Control and management connections (DTLS, OMP) to Cisco Catalyst SD-WAN Manager, Cisco Catalyst SD-WAN Validator, and Cisco Catalyst SD-WAN Controller
  • IPSEC tunnels for data traffic
  • IPv4 forwarding
  • L2 TLOC extension
  • Explicit ACL (Access Control Lists)
  • Implicit ACL on a port channel TLOC
  • IPv4 static routing
  • Loopback TLOC (ability to bind loopback to port channel)
  • Port channel sub-interfaces
  • Control policies on Cisco Catalyst SD-WAN Controller
Just want to notice you
there is different between l2 and l3 tloc extensions
It not same
MHM
