vEdge dropping connections to controllers
mfergusson
I am running vEdge 19.2.2 on EVE-NG PRO and having an issue with any vEdge dropping connections after a period of time.
After rebooting a vEdge and doing a show control connections, it shows connections to vsmart, vbond and vmanage with status "up". I can ping controllers fine, and then after a period of time which ranges from minutes to about 45 minutes, I lose all connectivity and can't even ping the neighbouring router. Only fix seems to be a reboot.
After posting the above, I just noticed that a show control connections-history has an initial vbond VB_TMO error (peer vManage timed out). Still doesn't solve the problem but a further clue ...
Any suggestion/comments please?
Thanks in advance.
Mark
this is most probably EVE-NG incorrect device resource issue. Use 1GB RAM and 1 vCPU per vEDGE.
HTH,
HTH,
HTH,
HTH,
Thanks Kanan, I will try. What's the reasoning behind this? (I actually tried "increasing" memory and cpu)
Thanks a lot Kanan, this resolved the issue for me. Much appreciated!
mfergusson
Thanks Kanan, that worked. Not sure why this is an EVE-NG resource issue particularly as the sizing I was using was double that so relatively small in the scheme of things. However, thanks for saving the day for me! Much appreciated.
