vEdge Flapping
UlquiorraCifer
hi,My vEdge is flapping, i don't know why, what root cause of this issue and how can i fix this?
7 Replies 7
UlquiorraCifer
BFD flapping
most common reason for BFD flapping is your SP connectivity. Did you check your circuits? Are there any packet loss?
no packet losss when i ping from vmanage to vedge
this problem is still continue .How can't i fix this?
Ping may be fine but neither the control connections nor the BFD sessions are ICMP. The flapping most likely points to a connectivity issue between your vedge and the controllers (for the control connection) or between your vedge and the other vedges (for BFD sessions).
exactly what is problem should be? do u need any information? it still flapping ,ping ok but i don't tracert sucessfull?
