vEdge not establishing control connection to vSmart over additional VPN0 WAN interfaces.
I'm setting up Viptela in an EVE-NG environment. Initial setup over using one WAN link works fine and control sessions are established to vSmart. However, when I add in another WAN connection (public-internet color for example), the dashboard says the control connections are only partially up, with vSmart expecting another control connection. IP reachability between the new interface and vSmart is tested and fine. I've tried invalidating the vEdge and re-validating, and same thing.
Unsure if I'm missing something here? I need to lab this with multiple WAN connections.
srimann4
I have the same problem , please let me know if you find any solution
below outputs are needed from vsmart and vedge:
sh control local-properties
sh control connections
sh control connections-history
Note: before getting last output better to clear control conections-histroy and let 3 5 min to try establish, then copy here above show output
HTH,
