vEdge - OSPF over GRE Tunnel
adnankhancisco
Dear Experts,
i am testing sdwan in my lab and trying to configure OSPF over GRE between vEdge-10 and border router. The configuration seems to be correct but they are not forming ospf neighbors. When i run tcpdump on vEdge, its only showing that its sending hello packets
vEdge-10-Cloud# tcpdump vpn 0 interface gre1
tcpdump -p -i gre1 -s 128 in VPN 0
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on gre1, link-type LINUX_SLL (Linux cooked), capture size 128 bytes
18:51:30.982618 IP 172.200.1.2 > 224.0.0.5: OSPFv2, Hello, length 44
18:51:40.983396 IP 172.200.1.2 > 224.0.0.5: OSPFv2, Hello, length 44
18:51:50.984086 IP 172.200.1.2 > 224.0.0.5: OSPFv2, Hello, length 44
18:52:00.984439 IP 172.200.1.2 > 224.0.0.5: OSPFv2, Hello, length 44
18:52:10.984839 IP 172.200.1.2 > 224.0.0.5: OSPFv2, Hello, length 44
But when i run wireshark on ge0/0 inside eve-ng, i can clearly see that this interface is getting hello packets from border_router also (172.200.1.1). Any idea what is wrong here?
Below is the configuration on vedge
vpn 0
name "Transport VPN"
router
ospf
router-id 10.10.10.10
timers spf 200 1000 10000
area 1
interface gre1
network point-to-point
exit
exit
interface ge0/0
ip address 172.16.10.10/24
tunnel-interface
encapsulation ipsec
color mpls
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service netconf
no allow-service ntp
allow-service ospf
no allow-service stun
allow-service https
no shutdown
interface gre1
ip address 172.200.1.2/24
tunnel-source-interface ge0/0
tunnel-destination 172.16.10.1
no shutdown
ip route 0.0.0.0/0 172.16.10.1
6 Replies 6
share border config as well also do debug ip ospf hello on border
HTH,
Sorry I was think it between two vedge.
I will check and update you
MHM
Thank you. will wait for your update please.
To check i  enabled ospf on ge0/0 and it formed successful adjacency with Border_Router. So i dont think its eve-ng problem. Somehow its not making adjacency over GRE.
encapsulation ipsec <<- change it to GRE
MHM
Thanks, let me check it in my lab and let you know. But out of curiosity, why this is required on the physical interface? and if i change it to GRE, will it still exchange OMP routes with vSmart?
Omp is exchange over dtls not ipsec nor gre.
But data traffic between vedge exchange via ipsec if you change encapsulate it will make vedge to vedge data traffic stop.
Try use instead of gre ipsec between vedge abd router
MHM
