after power outage cedge reboot and lost configurtion
vishwash
i have check cedge release its currently running 17.6.4 can anybody let me know what could be reason ?
before power outage cedge was not manage by via vmanage templates , it was manage via cli ..how and what  configuration (running config or startup config )  it will be retain once reboot happened ?
also somehow we repush the config on cedge but now issue is not able to ssh/remote  access cedge via ssh , however we can see it is insync with vmanage .?/
can anybody help for above question thanks in advance
ivances
Hi viswash
First, you need console access to the router.
Get this command: "show bootvar"
And then enter these commands and repeat "show bootvar"
configure terminal
boot system flash bootflash:packages.conf
boot system flash bootflash:prev_packages.conf
end
write
Reload the cEdge and see if it boots on controller mode.
ivances
Obviously, make sure that its not a connectivity issue
