vEdge Static NAT for Websever
Hello Team,
I have two vEdge virtual routers in Azure and I need a server that's behind them to be publicly available. Has anyone config'd this yet? I think I have a good understanding of what I need to do but figured to throw this out there.
svemulap@cisco.com
hi Gilbert -
One option would be:
You can attach another interface to the server that sits behind the vEdges and have a public IP to it. This way you can have reachability via public IP to the server. T
Hope it helps.
So you're saying there is no need for configuration on the vEdges?
Lei Tian
Is your vedge in same vNET as the server or vedge in a transit VNET?
My vEdge pair are in the same VNET as the server.
