vEdges v16.2.10 upgrade to v19.2.099
sdwan_mike
Beginner
Beginner
Hello everyone, so i have 8 new boxes of vedge-100b that came with version 16.2.10 (year 2017). I am trying to upgrade the software to the latest version 19.2.099. I have verified the hash of the image and i downloaded it without issues from cisco.
The problem is i cannot upgrade the vedge, i get the error:
WE# request software install-image viptela-19.2.099-mips64.tar.gz
rootfs.img: OK
rootfsimg.sig: OK
vmlinux: OK
crash.kernel: OK
kernel.sig: OK
u-boot-n818.bin: OK
u-boot-n820a.bin: OK
u-boot-n820b.bin: OK
u-boot-n820c.bin: OK
u-boot-n820f.bin: OK
u-boot-n821.bin: OK
u-boot-n822.bin: OK
n818_octboot2.bin: OK
n820_octboot2.bin: OK
Bad signing cert
Signature verification failed.
I cannot get the vedges connected properly with the controllers i have (on prem, version 19.2.099, i know the controllers/certificate are fine because i have 2x ASR 19.2version and those are working). I read a lot of release notes and it looks like i need to have around the same version of controllers and vedges. And this is why i decided to upgrade the vedges by CLi
While i might get a nice answer from this forum, i am thinking of doing an upgrade form 16.x to 17.x to 18.x then finally to 19.x
which will be a nightmare since i have more boxes coming.
**i wonder the same why cisco shipped these boxes with a 2year old OS.
RohitRaj03827
Beginner
Beginner
Open Tech case with Cisco.
Rohit Raj
I have the same problem ...
What did the TAC end up instructing you to do? Incremental upgrade to 18.x first?  Then 18x to 19x?
sasig
I presume your controllers running 19.2 , if you check the compatibility matrix, your vEdges running 16.x are not supported
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/19-2/sd-wan-rel-notes-19-2.html
Recognize Your Peers
