Viptela Underlay Routing
biran
Hi All,
Anyone can explain me how Data Plane IPsec tunnels form between edges using underlay multiple default routes?
I have confused how VEdge choose the correct transport default route to reach the VEdge it want to form the tunnel.
Best Regards,
Biran
2 Accepted Solutions
ekhabaro
It's quite simple, roughly speaking, you can consider it uses route via particular color only to establish connectivity with remote vEdge. Imagine for simplicity that color = vrf in terms of IOS.
Will Kerr
This is a good question.
Both underlay interfaces will be in VPN0.  While VPN0 does share a common routing table the interfaces will only use routes it learns on their local interface.
Say you have gi 0 and gi 1 in VPN0.  You will never see gi 1 use a route learned on gi 0 , even if its a more specific route.
5 Replies 5
ekhabaro
Oh , I think I understand now. Thanks.
Will Kerr
yeah , I think color make a segmentation for vpn 0 interfaces.
Thanks for your great discussion.
"Say you have gi 0 and gi 1 in VPN0. You will never see gi 1 use a route learned on gi 0 , even if its a more specific route."
If gi0 is outside and gi1 inside and both of them are in vpn 0, how is it possible to get a host on gi1 to access the outside network (over the underlay, without nat)?
