07-19-2023 04:34 AM
Greetings!
Requesting for help on the below vManage high availability (Disaster Recovery) configuration.
We want to deploy vManage controllers in active/standby (Disaster Recovery) configuration. One vManage will be in primary DC and second vManage will be in secondary or DR site.
Both vManage have a separate replication NIC configured.
vManage software version 20.6.5.
How we can achieve this? I can see one cisco document about "vManage cluster Disaster Recovery (DR)".
In order to have primary vManage sync the config with standby vManage in DR data center, is the configuration steps in the guide mentioned in the link is sufficient enough or are there more steps involved?
Any help in this regard is highly appreciated.
Many Thanks,
Girish
07-19-2023 06:35 AM
Good thread here https://community.cisco.com/t5/sd-wan-and-cloud-networking/does-arbitraror-supported-in-cisco/td-p/4866125 - see post by @Kanan Huseynli
09-12-2023 11:13 PM
Hello All,
Recently, we had configured the HA for vManage with Single mode in DC and Single mode DR setup.
Pre-requisites:
Configuration:
Once both vManages restart their services and come up, follow procedure below for DR Setup.
For further details, refer to below link,
HTH,
Girish
07-10-2024 09:07 PM
Hi, girish_gavamdi
Could you share with us the mentioned document, it is no longer available. We currently have to implement the same scenario.
White-paper-c11-741440
