vManage API: how to create a device tag
tbleise
I am trying to create a device tag through the vManage API. According to the API docs (SD-WAN vManage v20.9 - SD-WAN API - Document - Cisco Developer), the URI
POST /dataservice/tag
can be used for associating and creating tags. The sample payload given in the docs is only for associating tags. But how dow I actually create a tag if it doesn't exist yet?
Thanks!
Thorsten
use below payload
"create": [
"name": "TAG_NAME",
"tagId": "",
"tagType": "device"
Example is given in 20.11 doc:
https://developer.cisco.com/docs/sdwan/#!sd-wan-vmanage-v20-11
HTH,
use below payload
"create": [
"name": "TAG_NAME",
"tagId": "",
"tagType": "device"
HTH,
Hi Kanan,
that works, thank you!
You are welcome.
By the way, tagID you can give your own (like 100 200) and then reference easily in other APIs.
HTH,
