vManage Cluster Configuration Issue
RohitRaj03827
Hi All,
I am trying configure vManage cluster, i have two vManage , one vManage already running and i am trying to add new vManage into cluster. i have followed the below:-
sd-wan doc links. still not working
https://sdwan-docs.cisco.com/Product_Documentation/Getting_Started/Viptela_Overlay_Network_Bringup/03Deploy_the_vManage_NMS/06Create_a_vManage_Cluster
i went to Administration under that cluster management, under service configuration tab :-
clicked on add vManage , it gave me to enter the new vManage ip address and all, have done. says completed, still the second vmanage is not showing,
kindly help me if i am missing anything.
aspa
Rohit Raj
10 Replies 10
Which interface IP address are you using in vManage for clustering?
Srikanth
I am using three interfaces:-
eth0 ---- for VPN 0
eth1--- for OOB(GUI access)
eth2-- for cluster management.
Rohit Raj
Hi There
Are you implementing a vManage Cluster of 2 nodes? Are both vManage in the same L2 network?
That is already resolved.
Rohit Raj
Can you tell me which vManage version you are using?
Hi mindgame71,
I have used 19.2.099.
Rohit Raj
eth2-- for cluster management. >>> Do you add this interface in vpn0 without tunnel?
Hi Rohit,
Can You Tell More about the workflow you used for vManage clustering?
best regards,
ehsan
Ehsan Momeni Bashusqeh,
Workflow means you want to know how to configure vManage cluster or what?
Rohit Raj
Hi Rohit,
Yes, I Mean the steps for vManage Cluster Configuration.
Best Regards,
Ehsan
