Showing results forĀ
Search instead forĀ
Did you mean:Ā
vManage on EVE-NG: 100GB additional disk not showing
NadirPervez1
HI
I am using vManage image 20.6.3 and following all the steps mentioned in how to guide available EVE NG official site
https://www.eve-ng.net/index.php/documentation/howtos/howto-add-cisco-viptela-images-set/
i am using the following commands for additional disk
/opt/qemu/bin/qemu-img create -f qcow2 virtiob.qcow2 100G
/opt/unetlab/wrappers/unl_wrapper -a fixpermissions
but still opt/unetlab/addons/qemu/vtmgmt-20.6.3 folder showing a single disk. following is the output snapshot
/opt/unetlab/addons/qemu/vtmgmt-20.6.3:
total 3138628
-rw-r--r-- 1 root root 3213950976 Jul 18 19:31 virtioa.qcow2
also following is the snapshot from the console
Available storage devices:
sr00GB
1) sr0
Select storage device to use: Available storage devices:
sr00GB
1) sr0
 Select storage device to use: 1
Would you like to format sr0? (y/n): y
umount: /dev/sr0: not mounted.
mke2fs 1.43.8 (1-Jan-2018)
Could not open /dev/sr0: No medium found
on VM primary disk size is 200GB later i also added 150GB as additional disk but did not work.
please suggest a solution. thank you
JAVIERGUA
don't add a big disk only small like 20 GB is ok
Are you sure that you create the second disk in proper folder? Goto vmanage folder and try again:
cd /opt/unetlab/addons/qemu/vtmgmt-20.6.3
HTH,
That worked out perfectly for me
