Cisco C1111x-8P: High 'show process cpu platform' values
swscco001
Level 3
Level 3
Hello everybody,
out customer has a SD-WAN router:
cisco C1111X-8P (1RU) processor with 1971490K/6147K bytes of memory
running IOS Version 17.6.3a.
Our monitoning generated an alalm for high CPU load.
The command 'sh process cpu sorted' shows small values:
AT-IN-RT-0001# sh process cpu sort
CPU utilization for five seconds: 1%/0%; one minute: 1%; five minutes: 1%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 659         276         383        720  0.31%  0.05%  0.01%   1 SSH Process
  92    38010512    94348841        402  0.23%  0.20%  0.21%   0 IOSD ipc task
 141     3891156  1182038916          3  0.07%  0.01%  0.00%   0 L2 LISP Punt Pro
  86       90351     9963028          9  0.07%  0.00%  0.00%   0 SASRcvWQWrk1
   4           0           1          0  0.00%  0.00%  0.00%   0 Retransmission o
   3           0           1          0  0.00%  0.00%  0.00%   0 PKI Trustpool
   5           0           1          0  0.00%  0.00%  0.00%   0 IPC ISSU Dispatc
But in the 'sh tech' (attached) I found high values for the command
'show process cpu platform sorted':
------------------ show process cpu platform sorted ------------------
CPU utilization for five seconds: 95%, one minute: 92%, five minutes: 89%
Core 0: CPU utilization for five seconds: 99%, one minute: 92%, five minutes: 83%
Core 1: CPU utilization for five seconds: 99%, one minute: 90%, five minutes: 83%
Core 2: CPU utilization for five seconds: 90%, one minute: 92%, five minutes: 94%
Core 3: CPU utilization for five seconds: 97%, one minute: 97%, five minutes: 98%
   Pid    PPid    5Sec    1Min    5Min  Status        Size  Name
 14198   14181    173%    174%    176%  S           253440  qfp-ucode-tsn-l
  6902    4999     65%     68%     71%  R           981048  snort
 11670   11661     27%      3%      2%  R            15372  hman
 10483   10474     14%      2%      0%  S            73296  smand
  5158    4999     10%     11%     11%  R           271024  climgr
  9834    9826      9%     10%      9%  S          1356764  linux_iosd-imag
 13129   13104      5%      0%      0%  S            13848  btman
 16385   16361      3%      4%      4%  S             8664  ngiolite
 13892   13851      3%      3%      3%  S           147464  fman_fp_image
    34       2      3%      4%      5%  S                0  ksmd
  3635    3628      1%      1%      1%  S            61120  ftmd
 32206   32190      0%      0%      0%  S             7676  ngiolite
What could cause this high CPU-related load values and how this can be changed?
Thanks a lot for every hint!
Bye
R.
5 Replies 5
balaji.bandi
you have errors :
%IOSXE_QFP-2-LOAD_EXCEED: Slot: 0, QFP:0, Load 83% exceeds the setting threshold 80%
Do you see performance issue . try to increase this to 90%
platform qfp utilisation monitor load 90
check utilisation :
# show platform hardware qfp active datapath infra sw-cio
#show platform hardware qfp active datapath utilization
BB
swscco001
Level 3
Level 3
Hi Balaji,
thanks for the fast reply!
I will try to set the platform qfp utilisation monitor load to higher values but
how can I store the change permanently?
AT-IN-RT-0001(config)# platform qfp utilization monitor load ?
Possible completions:
  <0..65535, 50 .. 99>[80]
AT-IN-RT-0001(config)# platform qfp utilization monitor load 90
AT-IN-RT-0001(config)# wr mem
syntax error: unknown command
AT-IN-RT-0001(config)# copy ?
% Invalid input detected at '^' marker.
Thanks a lot!
Bye
R.
once you are in config mode try end or exit
then issue write mem
BB
dijix1990
Snort and traffic forwarding are cause. You need to monitor qfp and cpu utilisation. What about licence perf or hsec? On controlled mode without license 1111x can forward 250 mbit security traffic for all platform (in +out)
Leo Laohoo
The OS, IOS-XE, was designed specifically for multi-CPU operation.  And any platform running on IOS-XE is guaranteed to have multiple CPU.  The command everyone used to know and love, "sh process cpu sorted", gives only an average look of the data-plane.  It averages the total number of CPU in a nice form.
Use a different command to look at the control-plane:  sh process cpu platform sort location r0
