vManage SDWAN tunnel-interface
Gioacchino
Hi folks,
I'm trying to set up the "control-plane" for SD-WAN, meaning the certs and the conns among vManage, vSmart and vBond.
I configured the certs with vBond's/vManage's/vSmart's interfaces without the tunnel-interface option on but on the vManage device as soon as I bring up the tunnel interface I lose connection to the Web GUI.
I see that VPN0 is used for transport and should be eventually exposed to vEdges and the VPN 512 is used for the internal kitchen but in quite a few tutorial (Jedadiah Casey's for instance) people don't make any distinction between VPN0 and VPN512. They just use VPN0 (at the beginning with no encapsulation, then with it) and that's it. For them it seems everything is OK whereas I face the problem I described above.
Would be anyone be so kind to share their thoughts on this? I'm getting crazy. Can I use VPN0 for vMANAGE Web GUI? If yes, how?
Cheers, Gio.
Alex Mac
Make sure you have this under the eth0
vpn 0
 interface eth0
  ip address <...>
  ipv6 dhcp-client
  tunnel-interface
>>>   allow-service https <<<
Without the tunnel interface feature enabled I saw my browser using port 8444 too and indeed it listens on 8443 and 8444
vManage:~$ netstat -an | grep -e "844.*LISTE"
tcp6       0      0 :::8443                 :::*                    LISTEN
tcp6       0      0 :::8444                 :::*                    LISTEN
but I think allow-service https only permits 8443.
So make sure that you point your browser to 8443 since there is no daemon listening on 443.
Alex Mac
vpn 0
 interface eth0
  ip address <...>
  ipv6 dhcp-client
  tunnel-interface
Thanks! I did't pay attention, now I get back the GUI
