vmanageDB restore failed
K.Inaba-MD
It is an on-premise environment that cannot connect to the Internet.
version
 vmanage: 20.15.1
 vbond: 20.15.1
 vsmart: 20.15.1
I performed a backup and restore of vmanageDB by referring to the following site.
 https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/220305-standalone-vmanage-disaster-recovery.html
I run the following command, but I cannot proceed to the next step.
vmanage# request nms configuration-db restore path /home/admin/202503_configdb.tar.gz
tar (child): /home/admin/202503_configdb.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Backup vManage version: :
Current vManage version : 20.15.1
Aborting the restore because of version mismatch
vmanage#
The backed up version and the restored version match, but there is no value in the backup version field.
Does anyone know the cause or have experienced something similar?
11 Replies 11
Check whether the file exists at the /home/admin/
You can check it by using below commands.
vmanage# vshell
vmanage$ ls -al /home/admin
Thank you for your reply. It is as follows.
vmanage:~$ ls -l /ad home/admin/
total 2184
-rw-r--r-- 1 admin admin 2211740 Mar 19 06:42 20250319_configdb.tar.gz
-rw-r--r-- 1 admin admin 566 Mar 27 06:39 archive_id_rsa.pub
-rw------- 1 admin admin 18157 Mar 27 06:59 master_root.crt
vmanage:~$
I realized that the file permissions are 644.
Good to hear.
Is it solved after modifying permissions ?
Please remark this as a solution If this is helpful.
I can't check it today, but I'll check it tomorrow or the day after.
I made a mistake with the file name.
The execution results are as follows.
vmanage:~$ ls -al
total 2212
drwxr-x--- 4 admin admin 4096 Apr 2 03:46 .
drwxr-xr-x 14 root root 4096 Mar 27 06:33 ..
-rw------- 1 admin admin 421 Mar 27 07:37 .bash_history
-rw-r--r-- 1 root root 411 Mar 27 06:39 .bashrc
-rwxr-xr-x 1 admin admin 241 Aug 12 2024 .profile
drwx------ 2 admin admin 4096 Mar 27 06:57 .ssh
drwx------ 2 admin admin 4096 Apr 2 03:46 bk
vmanage:~$ cp -ip 20250319_configdb.tar.gz bk/20250319_configdb.tar.gz
vmanage:~$ ls -al bk/
total 2168
drwx------ 2 admin admin 4096 Apr 2 03:47 .
drwxr-x--- 4 admin admin 4096 Apr 2 03:46 ..
vmanage:~$ chmod 666 20250319_configdb.tar.gz
vmanage:~$ ls -al
total 2212
-rw-rw-rw- 1 admin admin 2211740 Mar 19 06:42 20250319_configdb.tar.gz
drwx------ 2 admin admin 4096 Apr 2 03:47 bk
vmanage:~$ exit
exit
vmanage#
It's not completed successfully.
Try to enter
vmanage# request nms configuration-db restore path /home/admin/20250319_configdb.tar.gz
The following command completed successfully.
Backup vManage version: : 20.15.1
vManage version compatibility check passed, proceeding with database restore.: 20.15.1 and 20.15.1
Starting NMS application server on localhost
Waiting for 180s for the instance to start...
Successfully restored database
vmanage#
Unable to re-authenticate the vbond and vsmart.
Hmm
So you've succeed to restore vManage DB now.
To establish control connections, troubleshoot step by step.
Also, vManage reboot may be helpful before any troubleshooting.
After the reboot, I executed the re-authentication of the vbond, but it still failed.
I performed the backup and restore by referencing the following site.
 Recover Standalone vManage by Disaster Recovery - Cisco
I have questions regarding the following.
1.
For Step 2 (Copy Backup Configuration and Root Certificate), should I only copy the root certificate of one vbond, or do I need to copy the certificates of all vbonds?
2.vbond has the following certificates. Which one is correct to copy ?
 master_root.crt
 vbond.crt
vbond-01:~$ ls -l
total 36
-rw-r--r-- 1 admin admin 565 Mar 4 05:07 archive_id_rsa.pub
-rw-r--r-- 1 admin admin 18157 Sep 4 2024 master_root.crt
-rw-r--r-- 1 admin admin 43 Sep 4 2024 root_ca_uuid_list
-rw-r--r-- 1 admin admin 1999 Sep 4 2024 vbond.crt
-rw-r--r-- 1 admin admin 1228 Sep 4 2024 vbond_csr
vbond-01:~$
I'm sorry, I cant answer for your questions.
I've never copied the certs into vBond via CLI.
About step 8, Did you do below things ?
1. Navigate to Configuration > Devices > Controllers
2. Click "Edit" for vBond.
3. Fill the parameters.
4. Check whether vBond cert is signed automatically or not after 3.
