03-30-2025 06:52 PM
It is an on-premise environment that cannot connect to the Internet.
version
vmanage: 20.15.1
vbond: 20.15.1
vsmart: 20.15.1
I performed a backup and restore of vmanageDB by referring to the following site.
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/220305-standalone-vmanage-disaster-recovery.html
I run the following command, but I cannot proceed to the next step.
vmanage# request nms configuration-db restore path /home/admin/202503_configdb.tar.gz
tar (child): /home/admin/202503_configdb.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Backup vManage version: :
Current vManage version : 20.15.1
Aborting the restore because of version mismatch
vmanage#
The backed up version and the restored version match, but there is no value in the backup version field.
Does anyone know the cause or have experienced something similar?
03-30-2025 07:43 PM
Check whether the file exists at the /home/admin/
You can check it by using below commands.
vmanage# vshell
vmanage$ ls -al /home/admin
03-30-2025 08:20 PM
Thank you for your reply. It is as follows.
vmanage:~$ ls -l /ad home/admin/
total 2184
-rw-r--r-- 1 admin admin 2211740 Mar 19 06:42 20250319_configdb.tar.gz
-rw-r--r-- 1 admin admin 566 Mar 27 06:39 archive_id_rsa.pub
-rw------- 1 admin admin 18157 Mar 27 06:59 master_root.crt
vmanage:~$
I realized that the file permissions are 644.
03-30-2025 10:10 PM
Good to hear.
Is it solved after modifying permissions ?
Please remark this as a solution If this is helpful.
03-30-2025 11:04 PM
I can't check it today, but I'll check it tomorrow or the day after.
04-01-2025 09:07 PM
I made a mistake with the file name.
04-01-2025 08:58 PM
The execution results are as follows.
vmanage:~$ ls -al
total 2212
drwxr-x--- 4 admin admin 4096 Apr 2 03:46 .
drwxr-xr-x 14 root root 4096 Mar 27 06:33 ..
-rw------- 1 admin admin 421 Mar 27 07:37 .bash_history
-rw-r--r-- 1 root root 411 Mar 27 06:39 .bashrc
-rwxr-xr-x 1 admin admin 241 Aug 12 2024 .profile
drwx------ 2 admin admin 4096 Mar 27 06:57 .ssh
drwx------ 2 admin admin 4096 Apr 2 03:46 bk
vmanage:~$ cp -ip 20250319_configdb.tar.gz bk/20250319_configdb.tar.gz
vmanage:~$ ls -al bk/
total 2168
drwx------ 2 admin admin 4096 Apr 2 03:47 .
drwxr-x--- 4 admin admin 4096 Apr 2 03:46 ..
vmanage:~$ chmod 666 20250319_configdb.tar.gz
vmanage:~$ ls -al
total 2212
-rw-rw-rw- 1 admin admin 2211740 Mar 19 06:42 20250319_configdb.tar.gz
drwx------ 2 admin admin 4096 Apr 2 03:47 bk
vmanage:~$ exit
exit
vmanage#
It's not completed successfully.
04-01-2025 09:14 PM
Try to enter
vmanage# request nms configuration-db restore path /home/admin/20250319_configdb.tar.gz
04-01-2025 09:36 PM
The following command completed successfully.
Backup vManage version: : 20.15.1
vManage version compatibility check passed, proceeding with database restore.: 20.15.1 and 20.15.1
Starting NMS application server on localhost
Waiting for 180s for the instance to start...
Successfully restored database
vmanage#
Unable to re-authenticate the vbond and vsmart.
04-01-2025 10:31 PM
Hmm
So you've succeed to restore vManage DB now.
To establish control connections, troubleshoot step by step.
Also, vManage reboot may be helpful before any troubleshooting.
04-01-2025 10:57 PM
After the reboot, I executed the re-authentication of the vbond, but it still failed.
I performed the backup and restore by referencing the following site.
Recover Standalone vManage by Disaster Recovery - Cisco
I have questions regarding the following.
1.
For Step 2 (Copy Backup Configuration and Root Certificate), should I only copy the root certificate of one vbond, or do I need to copy the certificates of all vbonds?
2.vbond has the following certificates. Which one is correct to copy ?
master_root.crt
vbond.crt
vbond-01:~$ ls -l
total 36
-rw-r--r-- 1 admin admin 565 Mar 4 05:07 archive_id_rsa.pub
-rw-r--r-- 1 admin admin 18157 Sep 4 2024 master_root.crt
-rw-r--r-- 1 admin admin 43 Sep 4 2024 root_ca_uuid_list
-rw-r--r-- 1 admin admin 1999 Sep 4 2024 vbond.crt
-rw-r--r-- 1 admin admin 1228 Sep 4 2024 vbond_csr
vbond-01:~$
04-01-2025 11:49 PM
I'm sorry, I cant answer for your questions.
I've never copied the certs into vBond via CLI.
About step 8, Did you do below things ?
1. Navigate to Configuration > Devices > Controllers
2. Click "Edit" for vBond.
3. Fill the parameters.
4. Check whether vBond cert is signed automatically or not after 3.
