vSmart image will not load in vContainer
jackfarrer
I am attempting to stand up a multi-tenant configuration in my lab.  I have created the vContainer server with a 20G second drive, loaded the viptela-smart-18.3.7-genericx86-64_vhd.tar.gz image into the admin home directory.  When I issue the request container image install /home/admin/viptela-smart-18.3.7-genericx86-64_vhd.tar.gz command, it sits for some time and then says 'Failure'.  Looking at the vcontainer.log in /var/log, I'm seeing the error below.  What would be causing this or how to fix it?
Wed Aug 14 17:14:34 UTC 2019: Running image_install cli image /home/admin/viptela-smart-18.3.7-genericx86-64_vhd.tar.gz
mount: special device /var/lib/docker/tmpvip/container/rootfs.img does not exist
Hilda Arteaga
Hi @jackfarrer
Thanks for posting your question on the Cisco Community. Currently we have a special event where a subject matter expert is answering all the questions related to SD-WAN.
Please feel free to post your questions there: https://community.cisco.com/t5/sd-wan/ask-the-expert-sd-wan-fundamentals-and-implementation/m-p/3910571
