Which Cisco switches usable and compatible with SD-WAN solutions?
ertanbar
Hey,
I have Cisco C1117-4P ISR already, use this routers for SD-WAN solutions. Is Cisco 2960X switches or 9200 series switches are compatible with them? I need a located a switch one of our companies locations.
I think Cisco make a table for this, which routers compatible to work with which switches for which solutions? I can not find any info about this Cisco products pages or in community Cisco forum.
Thanks for reply now
@ertanbar SD-WAN is a software-defined approach to managing the wide-area network, or WAN, not the LAN. HTH
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
6 Replies 6
@ertanbar you can find  Cisco SD-WAN Device Compatibility here
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/compatibility/sdwan-device-compatibility.html
Hey @bigevilbeard ,
I know this page and checked it already. But this includes routers and softwares that compatible with SD-WAN. But I wanna know a switch that compatible with this routers. So I have C1117-4P router and can I use a Cisco Catalyst 2960X-48FPD-L switch with this router?
@ertanbar you can use this switch with this router, but you cannot manage this switch with SD-WAN. HTH
Thanks for helps and reply,
But why? Any reason to can't manage this switch with SD-WAN? What's the differences this switches from other "SD-WAN manageble switches"?
Or which switches can I use with C1117-4P router with SD-WAN?
Thanks for helps,
Oh @bigevilbeard understood it now. I think we misunderstand in last messages. Ofc we manage LAN with switch not WAN, we'll manage SD-WAN with the 1117 Router, just wanted to ask Is this router compatible to work with this switch. I understand yes.
Thanks for time
