MX67C SD-WAN
Hi from what i was reading on the MX67C model, the SD-WAN aspect acts as a load balancer between the dual WAN interfaces, that the Meraki unit will not actually aggregate / or bond the bandwidth of both modems on each WAN ...
Is this correct?
Thanks!
Captain HoOmi
You're right it can only do Loadbalancing or Failover. In Loadbalance mode traffic will be spread across both links, it won't get aggregated :
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferences
https://community.meraki.com/t5/Security-SD-WAN/Meraki-mx64-with-two-Internet-connections/td-p/22295
** Please rate this post or accept the solution if it helped! :) **
Captain HoOmi
