Jason Burns
Purpose
Starting in CUCM 8.0.1 and IP Phone Firmware 9.X, IP Phones are now able to directly connect to an ASA using the AnyConnect VPN. This  document will help address some common issues encountered during intial configuration. This guide will act as a supplement to the Official IP Phone VPN Documentation.
Functional Overview
Before we get into versions and model numbers let's look at how the feature works.
CUCM Places ASA Certificate Hash and VPN URL in Phone Config
Before the phone is ready for VPN, it must first be provisioned using the internal network. This requires direct access to the CUCM TFTP server.
The first step after the ASA is fully configured is to take the ASA HTTPS Certificate and upload it to the CUCM server. This allows the CUCM server to build an IP phone config file that tells the phone how to get to the ASA. The CUCM requires some additional configuration to associate the uploaded certificate with a VPN Profile that can be assigned to the phone.
Here is an example of the IP Phone VPN section of a phone's config file after performing the required configuration:
jasburns@jasburns-gentoo /home/jasburns $ tftp 14.48.44.80
tftp> get SEP0011215A1AE3.cnf.xml.sgn
Received XXXX bytes in 0.0 seconds
jasburns@jasburns-gentoo /home/jasburns $ cat SEP0011215A1AE3.cnf.xml.sgn
<vpnGroup>
[Some Lines Omitted]
<addresses>
<url1>https://X.X.X.X/PhoneVPN</url1>
</addresses>
<credentials>
<hashAlg>0</hashAlg>
<certHash1>1eD9l3VEI9DGWQGKlNBGE1bRhUg=</certHash1>
</credentials>
</vpnGroup>
Note that the URL is printed exactly as entered on the VPN Gateway Configuration page in CUCM. Make sure the IP Phone can resolve this address.
Even more interesting is the Cert Hash. The IP phone configuration does not contain the entire certificate, merely a SHA1 Base64 encoded hash of the certificate.
You can compare the certificate hash in the IP phone configuration file to the cert hash of the actual file on the ASA or CUCM if you copy it to a computer running OpenSSL (either Windows, Linux, or Mac)
$ cat r2800.cisco.com.pem
-----BEGIN CERTIFICATE-----
<Base64 value of the cert omitted>
-----END CERTIFICATE-----
openssl x509 -in r2800.cisco.com.pem -noout -fingerprint
SHA1 Fingerprint=D5:E0:FD:97:75:44:23:D0:C6:59:01:8A:94:D0:46:13:56:D1:85:48
This is the SHA1 Fingerprint in Hexadecimal form. In the configuration file this value is instead printed as the Base64 value. I used the following website to convert from Hex to Base64:
http://tomeko.net/online_tools/hex_to_base64.php
This method can be used to verify the certificate loaded onto and presented by the ASA matches the certificate hash loaded into the phone.
Phone Downloads Configuration
This part is extremely important. The phone must download the configuration (including the certificate hash in Base64) while it is inside the network and has direct access to the CUCM TFTP server.
The phone has to be provisioned inside the network before it can be moved outside the network and use the VPN feature.
Phone Connects to ASA
After internal provisioning has been completed, the phone can be moved to the external network for VPN access. Here the Corporate Phone has been moved to a Home location.
Depending on the phone's configuration it will either automatically attempt to connect to the VPN gateway, or will connect once manually initiated. If auto network detect is enabled, the phone will try to ping the TFTP server. If there is no response to this ping request the phone will automatically bring up the VPN process on the phone.
The phone connects on TCP port 443 over HTTPS to the ASA. The ASA responds back with the configured certificate, hopefully the same certificate uploaded to CUCM. In additional TCP 443 (Transport Layer Security, or TLS), the phone will also connect on UDP 443 for DTLS (Datagram Transport Layer Security).
Phone Verifies Presented Certificate
The phone console logs show us the hash of the certificate that the ASA presents in Hex form:
3943: INF 18:10:22.354209 VPNC: vpnc_save_to_file: wrote: </tmp/leaf.crt>, 479 bytes
3944: NOT 18:10:22.355351 VPNC: cert_vfy_cb: peer cert saved: /tmp/leaf.crt
3945: NOT 18:10:22.361892 SECD: Leaf cert hash = D5E0FD97754423D0C659018A94D0461356D18548
3946: NOT 18:10:22.362574 SECD: Hash was found in the trust list
3947: NOT 18:10:22.400294 VPNC: VPN cert chain trusted
These messages show us that the phone was able to validate the certificate that the ASA presented. The cert presented matched the hash in the configuration file.
At this point the phone will establish an SSL session with the ASA and continue setting up the VPN tunnel.
All communication will now flow between the phone and the ASA in an encrypted tunnel. Once the traffic reaches the ASA it will be decrypted and forwarded along to any location in the network that the phone would like to connect to.
The beauty of this solution is that the phone obtains an address on the Internal network that is typically not filtered. The phone can connect using SCCP, SIP, HTTP, HTTPS to any server inside the Corporate Network. This allows advanced phone services and features to function that might not work through ASA Phone Proxy.
Software Versions
CUCM >= 8.0.1.100000-4
IP Phone >= 9.0(2)SR1S - SCCP
ASA >= 8.0.4
Anyconnect VPN Pkg >= 2.4.1012
Note: A "Premium" license and an "AnyConnect for Cisco VPN Phone" license is required.  The part number for the "AnyConnect for Cisco VPN Phone" is L-ASA-AC-PH-55XX= where XX = 05,10,20,40,50,80.
Phone Models
7942 / 7962 / 7945 / 7965 / 7975 / 8961 / 9951 / 9971. For a complete list of supported phones in your CUCM version go to:
https://<CUCM Server IP Address>:8443/cucreports/systemReports.do
Unified CM Phone Feature List
Generate a new report
Feature: Virtual Private Network
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_5_1/secugd/secuvpn.html
CUCM Configuration
The following document provides a complete set of configuration  tasks required to configure CUCM for this feature:
Note: Please make sure the URL for the VPN Gateway contains the full and correct address to reach the IP Phone VPN tunnel-group on the ASA.
Phone Configuration
  1. Use a supported phone model per the CUCM Supported Models / Features report.
  2. Register the phone to the CUCM server on the Internal network
  3. Configure the IP phone with a TFTP server manually.
  4. Move the phone to the external network.
ASA Configuration
Configure Anyconnect VPN access on ASA to provide network access.
See  http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808efbd2.shtml  for example configuration.
The lateset CUCM Security Guide also provides sample ASA configuration.
Additional Requirements:
  1. The ASA must have the AnyConnect for Cisco VPN Phone Licensed feature enabled.  Licensing info can be found using show version command.
  2. Group-policy must not be configured with split tunnel or split exclude.  Only tunnel all is the supported tunneling policy
  3. The tunnel-group used can not be the DefaultWEBVPNGroup.   Create another tunnel-group and use "group-url https://x.x.x.x/phonevpn enable to map to the correct tunnel-group.
  4. DTLS must be enabled and negotiated for operation.  This  requires both tcp/443 and udp/443 to be open and allowed on all devices between the ASA and the phone.
Troubleshooting Steps
  1. Plug the phone into the internal network.  This will test whether the phone's configuration works prior to adding VPN.
  2. Connect with AnyConnect on a PC from the outside to the ASA.  This will confirm that the ASA is configured correctly for Anyconnect
  3. From the connected PC try to ping the TFTP server and CUCM server.  This will test basic ip connectivity to the two servers.
  4. From the PC try to download the TFTP config file for the phone in question "tftp -i <TFTP Server> GET  SEP<Mac Address>.cnf.xml"  This will test that the tftp service is reachable and serving files.
  5. From the PC try to telnet to TCP Port 2000 on the CUCM server "telnet <CUCM IP> 2000". This should immediately come back with a new line and a blank cursor.  This will test connectivity to the CUCM SCCP port, for SIP registrations use port 5060 instead.
Common Issues
  1. One-way or no voice.  The phone registers and makes calls but no audio is heard.  Confirm routing between the two phone/rtp stream endpoints.
  2. Auto Network Detect does not reliably work in IP Phone Firmware 9.0(2), but does work as expected in 9.2(1).
    1. Auto Network Detect allows the phone to detect whether it is inside or outside the network. If outside it will bring up the VPN, if inside, it will connect directly.
    2. The phone uses a series of pings to the TFTP server to determine whether it is outside the network. If pings to the TFTP server fail, the VPN GUI will be brought up on the phone and the phone will attempt to access the VPN URL.
  3. Username and Password authentication from the phone does NOT support the SPACE character in either the username or the password.
madan.kumar
The VPN GW url is configured as a IP address.I have checked the phone status messages for that time it says "All concentrators failed"
I think there is some thing basic is missing not able to crack it
Anyhelp here is very much apprciated
Joseph Martini
The phone console logs are key to investigate this, if you have those we can take a look.
madan.kumar
Ok let me look at the console log and come back here
chrfowle
good stuff!!
Does anyone know if the phone Cert can also be leveraged by the ASA for VPN-Phone-trust?
or is it just Phone-VPN-trust using the ASA's cert on the phone (via CUCM), and then the ASA trusts the phone just from the Username/PW?
Also, has anyone used a CA to issue signed certs to the phones that the ASA could validate via the CA?
thanks for the great dialog!
madan.kumar
Hi Joe,
The below is the LOG message from Phone console
1087: NOT 13:10:18.180262 VPNC: VPN cert chain trusted
1088: DBG 13:10:18.181643 VPNU: SM wakeup - chld=0 tmr=0 io=1 res=0
1089: NOT 13:10:18.183502 VPNC: Using URL addr = (https://x.x.x.x/abcd)
1090: NOT 13:10:18.184080 VPNC: Host name = (x.x.x.x)
1091: NOT 13:10:18.184840 VPNC: Parsing host name from certificate...
1092: NOT 13:10:18.185512 VPNC: hostID not found in subject name
1093: ERR 13:10:18.186303 VPNC: hostIDCheck failed!!!
1094: ERR 13:10:18.188052 VPNC: ssl_state_cb: TLSv1: write: alert: fatal:unknown CA
1095: ERR 13:10:18.188968 VPNC: alert_err: SSL write alert: code 48, unknown CA
1096: ERR 13:10:18.189991 VPNC: create_ssl_connection: SSL_connect ret -1 error 1
1097: ERR 13:10:18.191394 VPNC: SSL: SSL_connect: SSL_ERROR_SSL (error 1)
1098: ERR 13:10:18.192406 VPNC: SSL: SSL_connect: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
1099: ERR 13:10:18.193416 VPNC: create_ssl_connection: SSL setup failure
1100: ERR 13:10:18.195227 VPNC: do_login: create_ssl_connection failed
1101: NOT 13:10:18.196442 VPNC: vpn_stop: de-activating vpn
1102: NOT 13:10:18.197296 VPNC: vpn_set_auto: auto -> auto
1103: NOT 13:10:18.197904 VPNC: vpn_set_active: activated -> de-activated
1104: NOT 13:10:18.198711 VPNC: set_login_state: LOGIN: 1 (TRYING) --> 3 (FAILED)
1105: NOT 13:10:18.199577 VPNC: set_login_state: VPNC : 1 (LoggingIn) --> 3 (LoginFailed)
1106: NOT 13:10:18.200518 VPNC: vpnc_send_notify: notify type: 1 [LoginFailed]
It says Host ID check failed i have tried disabling the Host id check field in the VPN   configuration still the issue persists.
Any inputs here is very much apprciated
Thanks in Advance
Joseph Martini
Looks like the "Enable Host ID Check" checkbox needs to be unchecked under the VPN profile in CUCM, since the URL is configured as an IP address and the certificate likely contains a hostname (so they don't match).
madan.kumar
" i have tried disabling the Host id check field in the VPN   configuration still the issue persists"
Joseph Martini
Was the phone internal when this change was made, so that it could download it's new configuration file with that change in it?
madan.kumar
no will check connecting it internal and let you know tomorw
fgasimzade
Level 4
Level 4
Each time you make a change in CCM configuration regarding VPN, you have to reset the IP phone to let him download new config
derveniss
Do I need to download any certificate from the cucm and upload to the ASA too?
And if so, which one?
joshfedor
Community Member
Can the ASA check a CRL list so that a phones access can be revoked?
jason , i followed the steps you menitoned and it worked very well. I had a question , in the ASA when i look at SSL VPN Cclient it shows me the MAC Address of the Phone as the username is there any way we can change it to some standard user id . We are using as Certificate only as the authentication.
pravfern
Hi Team.....Can anyone help me with a process to prevent the lost phones from connecting to the ASA.
Joseph Martini
If you are using username and password based authentication you can keep the phone from authenticated by deleting the user from the ASA, however the phone will still connect.  If you are using certificate based authentication you could change the certificates used by the ASA and phones so that the lost phone can no longer authenticate, however it will still try and connect.  The only way to prevent the phone from connecting completely would be to change the address (IP address) of your ASA and/or URL.  The phone will remember the address for the ASA until it downloads a new configuration file or is cleared (factory reset).
