Introduction
User has a standalone ISE, running at 1.1.4.218. While attempting to upload/install the patch bundle, nothing appears to happen. Under patch management, it is noticed "no data available". In the Operations Audit reports, there is no record of a patch install succeeding or failing or attempting.
Also the checked the md5 hash of the tarball, and the download matches the listed hash on the downloads page.
User is attempting patch 1using the web GUI as per the user guide. Which CLI command is it? application upgrade?
Solution
Use CLI To install a patch bundle of the application, use the patch command in the EXEC mode.
patch install patch-bundle repository
http://www.cisco.com/en/US/docs/security/ise/1.1/cli_ref_guide/ise_cli_app_a.html
Please ensure ACS is able to read the files in the repository before issuing the command.
Its a known issue with ACS 5.x and ISE.
Reference
This document was generated from the following discussion: ISE 1.1.4 patch not installing
