minkumar
    Introduction
    This document provides an example about latest feature of  ACS 5.4.  It gives you description on how to configure Login Banner (After Login  and Before login) on CLI and GUI interface of ACS 5.4.
    Requirements
    Ensure that you have configured ACS and can access the ACS through GUI as well through CLI access.
    Components Used
    The information in this document is based on these software and hardware versions:
    • ACS 5.4
    • ACS 1121
    The information in this document was created from the devices in a  specific lab environment. All of the devices used in this document  started with a cleared (default) configuration. If your network is live,  make sure that you understand the potential impact of any command.
    Conventions
    Refer to the Cisco Technical Tips Conventions for more information on document conventions.
    Configuration
    In this section, you are presented with the information to configure the features described in this document.
    Note
    Use the Command Lookup Tool (registered customers only) to obtain more information on the commands used in this section.
    For Before Login banner message:
    Step 1. Login to ACS GUI> Go to my workspace> click on login  banner > on the right hand side>Before login( configure the banner  message)
    Step 2: For configuring banner message after the login>Login to  ACS GUI> Go to my workspace> click on login banner > on the  right hand side>After login( configure the banner message)
    Verify
    This is how it will appear on the ACS GUI: Before Login:
    After Login on ACS GUI
    Before Login on CLI
    After Login on CLI
    Note:
    You can only configure the banner for 250 characters. More than 250 characters are not allowed. You cannot configure separate banner for CLI and GUI.
    Reference
    User Guide for Cisco Secure Access Control System 5.4 - Understanding My Workspace
    Please post comments if there are any queries and rate if useful
    Anim Saxena
    Hi Minakshi,
    Very Nice Document. Pretty helpful.
    minkumar
    Thank you very much
    Minakshi
