Problem
User tries to do EAP Chaining with PEAP but this is not working. How can we make this work?
Resolution
EAP chaining works with EAP-FAST and does not work with PEAP. It will be a bit more complex than using PEAP as we will be using EAP-FAST, EAP-MS-CHAPv2 and EAP-TLS. EAP Chaining requires both a supplicant on the client device and a RADIUS server that support the technology.
In Cisco ISE, Release 1.1.1, Extensible  Authentication Protocol (EAP) chaining solution allows you to  authenticate both the machine and user in the same EAP-FAST  authentication in a configurable order. When an EAP-FAST authentication  result is determined, Cisco ISE allows you to apply an authorization  policy, depending on the result of both authentications. When EAP  chaining is turned off, Cisco ISE performs the usual EAP-FAST  authentication.
Refer to EAP Chaining deployment for more information on EAP-Chaining process along with requirements
Source:https://supportforums.cisco.com/thread/2179660?tstart=0
mukka
Hi Prabhu
I have an issue trying eap chaining for machine and user authentication with certificate (tunnel EAP_fast with EAP_tls authentication):
When machine and user not have certificate, anyconnect is trying EAP PEAP.
11001
Received RADIUS Access-Request
11017
RADIUS created a new session
15049
Evaluating Policy Group
15008
Evaluating Service Selection Policy
15048
Queried PIP - DEVICE.Wired
15048
Queried PIP - Radius.Service-Type
15048
Queried PIP - Radius.NAS-Port-Type
15004
Matched rule - wire_teste
11507
Extracted EAP-Response/Identity
12100
Prepared EAP-Request proposing EAP-FAST with challenge
12625
Valid EAP-Key-Name attribute received
11006
Returned RADIUS Access-Challenge
11001
11018
RADIUS is re-using an existing session
12301
Extracted EAP-Response/NAK requesting to use PEAP instead
12303
Failed to negotiate EAP because PEAP not allowed in the Allowed Protocols
11504
Prepared EAP-Failure
11003
Returned RADIUS Access-Reject
 Do you have any idea about it ?
thanks,
