Suman Mukherjee
i am new in ASA field, i am wanted to configure the ASA 5510 with SSM 10 module (Trend Micro Module)
Say my public IP pool 10.10.10.10 /248
and my LAN IP pool 192.168.1.0/24
1st I wanted to internet through ASA. 2Mbps lease line terminate in Ethernet.
please any one help me, if possible.
my e-mail ID- kajal@chabria.com
sokakkar
Hi Kajal,
For setting up internet access on ASA:
Assuming that Ethernet0/1 is your internet interface and Ethernet0/2 is internal network:
Int e0/1
nameif outside
ip address 10.10.10.11 255.255.255.248
int e0/2
nameif inside
nat (inside) 1 0 0
global (outside) 1 interface
route outside 0 0 <next_hop_on_outside>
You can check the following link on how to initialize AIP SSM:
http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliInit.html#wp1031112
Then you need to set up policy on ASA to divert the traffic to SSM for inspection:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/ssm.html
Panos Kampanakis
Also to configure the CSC follow document
https://supportforums.cisco.com/docs/DOC-5668
I hope it helps.
PK
