ssdwcq1976
Community Member
We use VPN client on lots of computer. We configured several connections for our user. To monitor the connection status, we want to write a small application or batch file to monitor:
1. Which connection is established now?
2. When the connection is down, the application will send a msg to user or admin
3. When the connection is established instead of establishing, a msg also will be sent to user or admin.
I am not sure if CISCO VPN Client has SDK for us to write a VB application.
Sam
LAAsm2012b
having the similar question too, and noticed that the topic was posted last Dec, almost 1 year, no answer at all???
Hi Sam, did u figure it out yet? could u pls share it with me? thx.
