Sri Harsha Dasari
Symptoms
ISE 2.7 Patch5. SMS is not being sent to guests from Twilio after configuring according to below document.
https://community.cisco.com/t5/security-documents/ise-guest-sms-support-for-twilio-provider/ta-p/3637182
Diagnosis
1.We did a pcap on PSN and found that ISE server is not trusting Twilio cert even after adding DIGI cert root and intermediate certs
2.Even after fixing the cert issue, ISE says SMS sent but user is not receiving it.
Solution
For Problem 1, we are using a proxy in our environment, so, our Proxy is acting as a root CA and issuing a cert to api.twilio.com.
Even if we are not using any proxy settings on ISE, our traffic by default is going out through proxy and did not have any problems with Cisco Licensing portal. Now, we added our proxy root CA under trusted Certificates on ISE and SSL error is remediated.
For Problem 2
Instead of having $message$ under Data (Url encoded portion) section in SMS Gateway Settings, in ISE 2.7 we left that section empty and it worked. Rest, i followed the document in above link.
@Rahul Govindan
Joseph84174
Same issue still no fix to this.  Conduent Connect Feps
Sri Harsha Dasari
##- Does ISE message sent but you are not receiving the message or does ISE throw an error?
Also, which version of ISE are you running? -##
Thanks & Regards,
Sri Harsha Dasari.
Theodore
Facing same issue here. Help is appreciated.
dilipnelsonarul
I faced the same issue but above steps didn't resolve the issue, Have uploaded updated certs from Twilio (digicert signed) which fixed the issue.
