7200 with ghost cpa interface
gbarreraoro
Community Member
I have a 7200 router with a cpa interface. In show running config can be seen several interfaces channel(interface Channel2/0
no ip address
no ip directed-broadcast
ip mtu 0
no ip address
ip mtu 0)
There is only cpa instaled.
Anybody have any notice of this?
skoretsk
Community Member
Hi Gustavo,
I haven't seen that problem before. How are you accessing the CPA router - directly through the console/aux port using a terminal emulator like hyperterm (VT100, etc) from a PC, telnetting into the router, other ways? You might want to try accessing the router in some other way than how you did so when you saw the duplicate interface display. Are you certain you're not just seeing previous output saved in the buffer? Regards, Steve
I'm accessing to the router by telnet, but the same i get accessing by console. There are 3 interface in show run and show start commands.
show startup-config
ip address x.x.x.x x.x.x.x
no keepalive
csna xxxx xx
csna xxxx xx
max-llc2-sessions 2000
lan TokenRing 0
source-bridge xxx x xx
adapter 0 4200.0000.0024
lan TokenRing 1
source-bridge xxxx x xx
adapter 1 4000.0000.0004
name adap1
tn3270-server
maximum-lus 500
keepalive 65000
unbind-action keep
lu termination termself
pu xxxxxxx xxxxxxx x.x.x.x token-adapter 1 22 rmac 4000.0000.0004 #
pu xxxxxx xxxxx x.x.x.x token-adapter 1 24 rmac 4000.0000.0004 #
no ip address
ip mtu 0
no ip address
ip mtu 0
Regards.
Gustavo, this doesn't appear to be normal behaviour at all and I can't think of any operational reason why you would see the same Channel interface displayed 3 times! I recommend you open a case with Cisco TAC so they can troubleshoot the problem and hopefully provide a resolution. Regards, Steve
