Application Control Engine
arnis
has anyone started using the ACE module in the Cat6500 for server load balancing
Arni
thomas.chen
Level 6
Level 6
You access the CSM configuration from the command line by using the following IOS command:
conf t
mod con
The CSM uses its own vlans. The front vlan or client vlan is routable via a vlan interface. The server side vlan must not have a vlan interface in the configuration.
