Blade Switch - Layer 2 Trunk Failover
jandrews
Community Member
Does anyone know from experience on a 3020 or GESM HP blade switch if downstream ports are recovered automatically when an uplink port recovers from a failure? I have seen references to the downstream ports being put in err-disabled state and was curious if they needed to be recovered manually even after the upstream recovers. Thanks.
kcoley
Yes, the downstream ports come up automatically when the upstream ports come back active.
