channel connection from 7204vxr to VM
2tramsay
Hi!
I'm trying to get a subchannel link going between an IBM Z-series box running VM and my 7204VXR router with a CPA card in it. I have the same setup working on our production box, but the new one won't work. I'm close, but no matter what we do, we cannot vary the path online in VM, and the subchannel display shows as offline. Pertinant info and displays are attached. Not sure what I'm missing. No matter what we try, the subchannel remains offline. I have this working to our production VM system on the same 7204 (different interface). Any ideas??
The second "1" in the path 0110 says that we are
hearing from LPAR #1. Try configuring:
csna 0110 00
Jim
7 Replies 7
wong34539
Level 6
Level 6
In which interface of 7204, you have connected or created this subchannel link? get the output of show interface intf type no at your router console. And also, while debugging, wht is the error message you receive?
Thanks for the reply... The interface is 4/0. Interface 1/0 is currently working on our production box. I haven't gotten any error messages from the debugging I've tried; I'm either not turning on the correct debugging, or as far as the 7204 is concerned there is no error. Sh interface output:
wpg7204bk#sh int ch 4/0
Channel4/0 is up, line protocol is up
Hardware is Escon Channel
Internet address is 10.10.10.1/24
MTU 4472 bytes, BW 98304 Kbit, DLY 100 usec,
Encapsulation CHANNEL, loopback not set
ECA adapter card
Data transfer rate 12 Mbytes, number of subchannels 4
Last input 1w0d, output 1w0d, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: fifo
Output queue :0/40 (size/max)
69 packets input, 3827 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
75 packets output, 4604 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Are you running LPARs? Is this CHPID dedicated?
Please do:
if-con 4 c
show-elps 0
if-quit
and let me know what it says.
Jim
Thanks for the reply Jim...
I learned a couple new commands today :)
Output as follows:
Path 0100, Result Path established, Count 19
Path 0110, Result Not established, not configured, Count 333
We have a single LPAR, and the CHPID is dedicated to that LPAR.
csna 0110 00
Jim
Thank-you!!! That did it...
Great!
Be careful with those commands.
Jim
