Cisco UCS Blade Server - USB connection
I have a Cisco UCS B200 M3 Blade Server and I want to see the USB at the BIOS of the VM. I know there are two way to connect USB: via KVM cable or via Internal USB port. I need to know what are the differences between this two method. Someone knows what are the differences?
Thanks in advance.
Roberto Loiudice
Walter Dey
Ciao Roberto
Don't use the KVM cable (dongle); this should only be used for troubleshooting purpose.
You have 2 choices: Internal USB, or SD card.
UCS-USBFLSH-S-4GB
4GB Flash USB Drive (shorter) for all M3 servers
Dual SDHC flash card sockets are provided
 on the front left side of the server.
NOTE:
Dual card support (mirroring) is supp
orted with UCS Manager 2.2.x and later
UCS-SD-32G-S
32 GB SD card module for UCS servers
B200-M3 specs: http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/B200M3_SpecSheet.pdf
Walter.
Walter Dey
Ciao Roberto
UCS-USBFLSH-S-4GB
NOTE:
UCS-SD-32G-S
Walter.
