CSS content configuration problem
marta.sokolowska
Community Member
I've a strange problem with CSS configuration (written below). In 10% of times, content "ABCD80old2" doesn't work - clients trying to access "/AB*" resources, receive answers from Serv3 and Serv4 (not from Serv1 or Serv2, as they should). Upgrade to the version 8.2.01 didn't resolve the problem.
Here's the configuration from CSS 11506:
content ABCD80old2
vip address 10.30.4.254
advanced-balance sticky-srcip
sticky-inact-timeout 120
add service Serv1
add service Serv2
port 80
protocol tcp
url "/AB*"
active
content ABCD80
protocol tcp
port 80
add service Serv3
add service Serv4
active
Thank you in advance for any ideas.
vadi_ag
Community Member
Kindly help me understand why u have added this url "/AB*" in content ABCD80old2 i see a problem here cos the content ABCD80 looks for protocol tcp port 80 only and where as
content ABCD80old2 looks for port 80
protocol tcp url "/AB*" this cud be the reason for this issue to solve this u can add add service Serv1 add service Serv2 in
content ABCD80 and try this works out
Vadi
I have to configure different content for URL /AB*, because such resources reside on different servers. So, if clients are incorrectly redirected to Serv3 or Serv4, they get "Page not found".
Configuration for services:
service Serv1
ip address 10.30.2.22
protocol tcp
port 80
keepalive type tcp
keepalive tcp-close fin
keepalive frequency 20
active
service Serv2
ip address 10.30.2.23
protocol tcp
port 80
keepalive type tcp
active
service Serv3
ip address 10.30.2.24
port 80
keepalive type tcp
protocol tcp
active
service Serv4
ip address 10.30.2.25
port 80
keepalive type tcp
protocol tcp
active
Correct me, if I'm wrong, but I read, that CSS looks for the most _exact_ content first - so URL with /AB* should be processed with content ABCD80old2, which is more precise than content ABCD80.
We also have a very similar problem, we are using two servers and two content Content Rules. About two or three times a day URL requests that match content rule 1 which should go to server 1 actually go though to server 2 causing HTTP errors such as 404 etc. Is this a know bug? any help would be much appriciated.
Stephen
