data center network design considerations - static route
xh_liu
data center network should be simple.
I think you agree with this.
so i think data center netowrk should use staic route first, and i think static route is enough for data center network.
staic route with hsrp and firewall(failover) can get high availablity.
i always persuade my customer use staic route, not dynamic routing protocol.
i think staic route is more simple and ease use than dynamic routing protocol.
data center network should be steady, simple netowkr is more steady, ease maintenance.
so i think data center network should use staic route first.
and the second question:
do you want data center firewall running dynamic routing protocol like ospf?
i think data center firewall must use staic route. because data center firewall running dynamic routing protocol is not steady, i think more software bug or other question exist if firewall running dynamic routing protocol.
do you think so?
so my data center network desigh opinion is:
data center network should use staic route.
static w/ hsrp and firewall failover can get high availability.
data center firewall should use staic route, not dynamic routing protocol.
firewall runing dynamic routing protocol is not a good idea.
is there any data center network desigh guideline or principle (especially routing protocol choice, firewall running mode)?
how about your opinion?
thank you.
17 Replies 17
Hi..
Thanks this is fine...If i enable spanning-tree portfast bpduguard default globally..it will effect to all the interfaces include trunkports also right...
If I enable bpdu globally anything is going to happen???
sateesh kumar.k
Sateesh,
If you do not know what "spanning-tree portfast bpduguard default" does or means, then you need to do some reading, BPDU guard:-
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
You also need to read up on spanningtree fully.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/sw_ntman/cwsimain/cwsi2/cwsiug2/vlan2/stpapp.htm
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml
HTH>
If you read the SRND and look at your requirements, you should be running layer 3 anywhere possible, with an IGP.
