FCoE - nexus 4000/5548UP - vfc down (Initializing)
Surya ARBY
Level 4
Level 4
Hi all.
I have : nexus 5548UP (5.0(3)N2(1)) with nexus 4000  in Bladecenter-H (last code 4.1(2)E1(1g)).
The config is quite basic and compliant with all best-practices.
Everything went fine until we saw some strange things, we decided to reboot everything. One of the strange things was that my vfc has gone into TF (Trunking F port) at some point, which is totally unexpected. When everything worked it ran as a standard F port. Now trunk mode is "on" on the vfc, I don't know if it's normal or not.
Now I have a VFC which is stuck in "down (Initializing)" state.
N5K-01# show interface vfc 103
vfc103 is down  (Initializing)
    Bound MAC is 00:c0:dd:1b:82:c5
    Hardware is Virtual Fibre Channel
    Port WWN is 20:66:54:7f:ee:08:ec:bf
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 2
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
The VFC is correctly bound to the right mac-address learnt via fip-snooping
N5K-01# show run int vfc 103
interface  vfc103
  bind mac-address 00:c0:dd:1b:82:c5
  no shutdown
N5K-01#
NX-BCH1-M7# show fip-snooping vlan-discovery
  Legend:
      Interface      VLAN          FIP MAC
      Eth1/3         1         00:c0:dd:1b:82:c5
NX-BCH1-M7#
I believe it's "down (Initializing)" because of FIP negociation not complete ?
Upstream FCF is seen from the 4000
NX-BCH1-M7# show fip-snooping fcf
   Legend:
Interface VLAN Active FPMA/ FCMAP      FCF-MAC   Pri   Switch WWN  Fabric Name
               Enodes SPMA
por2      600  0      FPMA 0x0efc00 54:7f:ee:08  128  10:00:00:05: 10:00:00:05:
                                    :ec:a7            1e:90:4a:0b  1e:90:4a:0b
                                    :ec:a6            1e:90:4a:0b  1e:90:4a:0b
No more session or enode detected through the 4000 (it was working before)
NX-BCH1-M7# show fip-snooping enode
NX-BCH1-M7# show fip-snooping sessions
NX-BCH1-M7#
It seems that the driver on the host still sends FIP messages as I can read on the 4000
NX-BCH1-M7# show fip-snooping counters interface ethernet 1/3
  Legend:
Interface Name    Counter  Desciption                                Value
Ethernet1/3       Unicast packets received                          0
                  Multicast packets received                        9
                  Vlan discovery packets received                   9
                  Vlan discovery response packets received          0
                  flogi (fabric login) packets received             0
                  flogi lsacc (acknowledgment) packets received     0
                   flogi lsrjt (reject) packes received              0
                  fdisc packets received                            0
                  fdisc lsacc received                              0
                  fdisc lsrjt  received                              0
                  logo (logout) packets received                    0
                  logo lsacc received                               0
                  logo lsrjt  received                               0
                  Enode Keepalive received                          0
                  Enode Discovery received                          0
                  FCF Discovery Solicit  received                    0
                  FCF Keepalive received                            0
                  Clear Virtual Link received                       0
                  Clear Virtual Link generated                       0
                  Unicast packets transmitted                       0
                  Packets dropped due to invalid length             0
                  Packets dropped due to tlv parse error            0
                  Packets dropped due to unsupported tlv             0
                  Packets dropped due to fcmap mismatch             0
NX-BCH1-M7# show lldp traffic interface ethernet 1/3
LLDP traffic statistics:
    Total frames out: 44
    Total Entries aged: 0
    Total frames in: 43
    Total frames received in error: 0
    Total frames discarded: 0
    Total TLVs unrecognized: 0
NX-BCH1-M7#
My last idea is to configure a SPAN session on the 5000 and see with wireshark what is going on. Are there any extra commands that can help me before sniffing ? (show, debug...)
I suspect an issue on the host, where can I find the compatibility matrix for FCoE ?
16 Replies 16
yep, in fact the smartnet has been ordered but it still not fully in the end of the process.
Finally got the answer : there is a bug with VSAN 2. If we change it to VSAN 3 no problem.
