FEX 2232TM not recognized by Nexus 5010P
PrimergyQA
Hi there,
I don't have any clue what this problem might be so please help.
I have a brandnew FEX 2232TM which is connected to a NEXUS 5010P running the following firmware:
oftware
  BIOS:      version 1.5.0
  loader:    version N/A
  kickstart: version 5.2(1)N1(1)
  system:    version 5.2(1)N1(1)
  power-seq: Module 1: version v1.2
  BIOS compile time:       11/30/10
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.2.1.N1.1.bin
  kickstart compile time:  7/12/2012 19:00:00 [07/13/2012 02:08:13]
  system image file is:    bootflash:///n5000-uk9.5.2.1.N1.1.bin
  system compile time:     7/12/2012 19:00:00 [07/13/2012 03:23:16]
According to the Cisco download page it is the latest version and should definitely support the 2232TM.
The problem is that the FEX is completely not recognized by the parent Nexus.
It is connected via 8 FET modules. But when ich check the light on both sides I only have light on the NEXUS side never on the FEX side on all modules.
From my understanding this should be the root cause of the issue because no light = no link.
I tried standard 10GBase-SR and Twinax cables as well. Same behavior - the FEX is not recognized.
The status LED if of course orange on the FEX.
This is the FEX related config ont he NEXUS:
feature fex
fex 101
  pinning max-links 8
  description "FEX0101"
interface Ethernet1/1
  switchport mode fex-fabric
  fex associate 101
interface Ethernet1/2
  fex associate 101
interface Ethernet1/3
  fex associate 101
interface Ethernet1/4
  fex associate 101
interface Ethernet1/5
  fex associate 101
interface Ethernet1/6
  fex associate 101
interface Ethernet1/7
  fex associate 101
interface Ethernet1/8
  fex associate 101
Can anyone give me a hint what I am missing here??
Any help is really appreciated.
Thanks a lot!
9 Replies 9
Reza Sharifi
What is the output of "sh fex"?
Also, are you using Multimode fiber patch cords?
Hi Reza,
thanks for answering.
The "sh fex" output shows nothing which is actually expected because the FEX wasn't discovered yet.
And yes Multimode fiber cables are used for the setup. But as mentioned before I can see no light in the transceiver on the FEX side. The problem is I dont' know why :-(
Faulty SFP or faulty fibre optic patch cable?
I am using 8 ports so it's very unlikely that all transceivers and cables are defect.
I have also connected this FEX to another NEXUS -> no success
and also another FEX to this NEXUS -> success
So it looks like the 2232TM has a hardware problem.
I have a two lab switches running 5.2.1.N1.1 and connected in vpc with 2232TM and I am able to see the fex online without any problems. One side I have SFP-10G-SR and other side I have 3M Cisco Twinax cable.
here is the output from my lab,
5010-1# show fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
100        FEX0100                Online    N2K-C2232TM-10GE   SSI15380CPM
5010-1# show fex 100 detail
FEX: 100 Description: FEX0100   state: Online
  FEX version: 5.2(1)N1(1) [Switch version: 5.2(1)N1(1)]
  FEX Interim version: 5.2(1)N1(1)
  Switch Interim version: 5.2(1)N1(1)
  Extender Serial: SSI15380CPM
  Extender Model: N2K-C2232TM-10GE,  Part No: 73-13626-03
  Card Id: 164, Mac Addr: 28:94:0f:2e:12:82, Num Macs: 64
  Module Sw Gen: 21  [Switch Sw Gen: 21]
  post level: complete
  Pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/1
  FCoE Admin: false
  FCoE Oper: true
  FCoE FEX AA Configured: false
  Fabric interface state:
    Po100 - Interface Up. State: Active
    Eth1/1 - Interface Up. State: Active
  Fex Port        State  Fabric Port
5010-1# show interface e1/1 transceiver details
Ethernet1/1
    transceiver is present
    type is  SFP-H10GB-CU3M rev A
    name is CISCO-MOLEX INC
    part  number is 74752-9026
    revision is A
    serial number is  MOL12240343
    nominal bitrate is 12000 MBit/sec
    Link  length supported for copper is 3 m
    cisco id is --
     cisco extended id number is 4
DOM is not supported
5010-2# show fex
  FEX         FEX           FEX                       FEX
5010-2# show fex 100 detail
  FCoE Admin: false
  FCoE Oper: true
5010-2# show interface e1/1 transceiver details
Ethernet1/1
    type is 10Gbase-SR
    name is CISCO-AVAGO
    part number is SFBR-7700SDZ-CS2
    revision is B5
    serial number is AGD133133S4
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 50/125um OM3 fiber is 300 m
    Link length supported for 62.5/125um fiber is 26 m
    cisco id is --
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   44.18 C        75.00 C     -5.00 C     70.00 C        0.00 C
  Voltage        3.26 V         3.63 V      2.97 V      3.46 V        3.13 V
  Current        6.48 mA       10.50 mA     2.50 mA    10.50 mA       2.50 mA
  Tx Power       -2.62 dBm       1.69 dBm  -11.30 dBm   -1.30 dBm     -7.30 dBm
  Rx Power       -2.80 dBm --    1.99 dBm  -13.97 dBm   -1.00 dBm     -9.91 dBm
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
So dont believe we have any interoperability issue with 5010 and 2232TM here. Before we swap out this fex, can you please open a case with Cisco support or let me know when you are available and I can do a webex to look at this switch to see if there is something more to this problem than what we already know ?
Vinayak
Hi Vinayak,
thanks for your help. In the meantime I have already opened a case with Cisco (622584585).
I have send debug output of the FEX to the assigned TAC engineer. Maybe he has attached it to the case so you can also have a look.
Ok thanks, i will follow up on this one with the tac engineer.
Vinayak
Hi Vinayak,
no need to investigate further. According to the TAC the FEX needs to be RMAed.
yes, I had a chat with the TAC engineer yesterday on this. Was aware of this
thanks, Vinayak
