help
JackR252
Visitor
edited cleared case
10 Replies 10
alfredofficial0007
Frequent Visitor
Frequent Visitor
I had the same issue few days back but I got it fixed from a ransomware recovery service.
where did you get it? are you sure it can decrypt akira ransomware???
I'll check with them, thank you for the suggestion.
they have decrypted the samples should I continue with them???? what's your final recommendation?
You should go with them. They are professionals and can help you in resolution of this ransomware.
https://monsterclouddecryptor.com/ Monster Cloud decryptor scammed me out of $9K. I sent them sample files, and they said they decrypted them, but they probably just used the Akira site. They are pretending to be https://monstercloud.com/. They are no better than the hackers that attack your system.
alfredofficial0007
Frequent Visitor
Frequent Visitor
They may also help you in hardening of your servers after restoration and malware cleaning too as they did to me.
Thank you very much! They helped me restore my environment back to normal.
alfredofficial0007
Frequent Visitor
Frequent Visitor
You are welcome.
