How to check port utilization in Nexus 5k?
jmp780718
Hi.
How i can check the port utilization in Nexus 5k?
Thank you.
richbarb
Hello jmp,
There are many ways to do that. (DCNM, CLI, SNMP, etc.)
The most simple is just by the commando "show interface ", look the output and input rate.
You can specify up to 3 load interval to measure the traffic, use the command "load-interval" under the interface.
Follow the reference:
http://www.cisco.com/en/US/partner/docs/switches/datacenter/nexus5500/sw/command/reference/interfaces/n5500_if_cmds_l.html#wp2291298
