Input packet drops on Nexus 1000v
alioune-ndiaye
Hello guys,
Could you help me to get the right answer?
description
I get alot of Input packet drops ,
N1K-DC1-01-INT# sh int | i drop
    21999658 input packet drops
    0 output packet drops
    21998884 input packet drops
    46233225 input packet drops
    21999657 input packet drops
Uplink mode command is  "channel-group auto mode on mac-pinning"
for example:
port-profile type ethernet DvSUplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 8,11,39,88,108-115,149-150,152-159,302
  no shutdown
  system vlan 150
  description VLAN 108-115 PRODUCTION
  state enabled
We clear the interfaces ; however ,the  command  show int | egrep -i "ethernet|drop" displays input packet drop again, see below
N1K-DC1-01-INT# clear counters  [31D [J
N1K-DC1-01-INT# show int | egrep -i "ethernet|drop"
  Hardware: Ethernet, address: 0050.56a5.0004 (bia 0050.56a5.0004)
Ethernet3/4 is up
  Hardware: Ethernet, address: 0050.5650.05af (bia 0050.5650.05af)
    50 Input Packet Drops 0 Output Packet Drops
Ethernet3/8 is up
  Hardware: Ethernet, address: 0050.5650.037e (bia 0050.5650.037e)
    55 Input Packet Drops 0 Output Packet Drops
Ethernet4/4 is up
  Hardware: Ethernet, address: 0050.5650.014d (bia 0050.5650.014d)
Ethernet4/8 is up
  Hardware: Ethernet, address: 0050.5650.018d (bia 0050.5650.018d)
Nexus 1000v:4.2(1)SV2(1.1a)
UCS en version 2.1.3
Vsphere 5.1
Appreciate any help.
Alioune
5 Replies 5
Steve Fuller
Level 9
Level 9
Hi Alioune,
This is expected behaviour on the Nexus 1000v Ethernet interfaces when the uplinks are configured with MAC pinning.
When using MAC pinning there's no special configuration of the ports on the upstream physical switches and so any broadcast packets are sent by the upstream switches on all uplinks towards the Nexus 1000v switch.
On each VEM of the Nexus there's one uplink interface that is chosen as the Designated Receiver for broadcast traffic, and the function of the DR is to forward received broadcast traffic to VMs within the VLAN. The broadcast traffic received on any other uplinks of the VEM i.e., those that are not the acting as DR, drop the received broadcast traffic on ingress to the VEM.
The drops you're seeing on the uplink interfaces are almost certainly the broadcast traffic being received on one or more non DR uplinks.
How can you see which interface is the DR?
what is your UCSM version
you can check through CLI
SSH to FI
connect nx
sho platform  software enm  internal  info vlandb id xxx
Thanks Ahsan, your command may work for UCS, but what about Nexus 1000v?  I found this command which is supposed to show the designated receiver, but out output is not what I expect to see.
vemcmd show dr
It says the DR is the port-channel interface.  I expected it to list a member interface, not the port-channel.
Example
Switch# module vem 27 exec vemcmd show dr
BD 7, vdc 1, vlan 3642, 4 ports, DR 561, multi_uplinks TRUE
Portlist:
     17     vmnic0
     18     vmnic1
     49     vmk0
    561  DR
BD 8, vdc 1, vlan 3645, 4 ports, DR 561, multi_uplinks TRUE
Portlist:
     17     vmnic0
     18     vmnic1
     52     vmk3
    561  DR
Switch# module vem 27 exec vemcmd show port
  LTL   VSM Port  Admin Link  State  PC-LTL  SGID  Vem Port  Type
   17    Eth27/1     UP   UP    F/B*    561     0    vmnic0
   18    Eth27/2     UP   UP    F/B*    561     1    vmnic1
   19    Eth27/3     UP   UP    FWD     562     2    vmnic2
   20    Eth27/4     UP   UP    FWD     562     3    vmnic3
   21    Eth27/5     UP   UP    FWD     563     4    vmnic4
   22    Eth27/6     UP   UP    FWD     563     5    vmnic5
   49     Veth97     UP   UP    FWD       0     0      vmk0
   50     Veth98     UP   UP    FWD       0     0      vmk1
   51     Veth99     UP   UP    FWD       0     0      vmk2
   52    Veth100     UP   UP    FWD       0     1      vmk3
(---cut--)
  561       Po25     UP   UP    F/B*      0
  562       Po85     UP   UP    FWD       0
  563       Po91     UP   UP    FWD       0
•Each uplink is assigned a SGID based on vmnic number (vmnic0 = SGID 0, vmnic1 = SGID 1, etc)
•Each VM is pinned to a SGID in a round-robin fashion
