Is Nexus 7009 supported in Solarwind NMS
rehan_uet
Is Nexus 7009 supported in Solarwind (NPM) network management solution for SNMP poll?
Can we read the CPU utilization & environment monitoring of Nexus 7009 through Solarwind NPM?
iftahmed
Please find attached the document from solarwinds website.
I hope this helps.
Hello iftahmed, the question was about CPU utilisation and environment monitoring, not netflow.
Rehan, yes you can, use SNMP here is my sample I use Orion NPM to monitor N7Ks as well.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
What version of solarwind are you using?
Can we monitor the environment (temperature) of N7K in solarwind?
Hello Rehan, we are using Orion NPM 10.6 - yes you can monitor the environment temperature, as you can see from the screenshot in my previous post.
Hope this helps.
B
