Max Switching Capacity of N7K
Yan Tian
Hello all,
From Cisco official site, http://www.cisco.com/en/US/products/ps9402/index.html
it states, Nexus 7000 supports up to 17.6 Tbps Switching Capacity, however, I strongly doubt that.
From my understanding, I/O line cards have Fabric Connection of up to 80Gbps for M1, 240Gbps for M2, and 480Gbps for F2 series.
And Fabric Module provides up to 550Gbps capacity.
We can not just sum them all up as they can not achieve max capacity concurrently. (let's say, 8 F2 series I/O modules and 5 Fabric Modules installed)
Can anyone please tell how 17.6 Tbps comes out?
Thanks in advance.
richbarb
Tian,
This is simple one.
This number 17.6Tbps is achieved with Nexus 7018 populated with 5 fabric2 and 16 modules F2.
The switch populated with Fabric2, each module has 550Gbps (value half-duplex) x 16 modules F2 in Nexus 7018 = 8800Tbps x 2 (full-duplex)= 17.6Tbps.
Module F2 datasheet, explain the fabric2 velocity with.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-685394.html
6 Replies 6
richbarb
Tian,
This is simple one.
Hi Richard,
Thanks for your reply, but I still can't agree with your calculation I am afraid.
when 1 F2 modules forwards packets through Switch Fabric (5 Switch Fabrics support up to 550Gbps BW), then 480Gbps of Switch Fabrics have been exclusively occupied by that F2 modules in that moment, and only 550-480=70Gbps is left in Switch Fabric for the other F2 modules.
What is more, each F2 modules has up to 480Gbps Fabric Connection, which mean it can achieve throughput of 480Gbps when packet ingress and egress on the same module, (no Switch Fabirc will be occupied).
So, the scenario for N7K to achieve its max throughput will be 1 F2 module forwards traffic throught Switch Fabric and all other 15 F2 modules just forward traffic locally (packets forwarded no through Switch Fabric).
Max Throughput would be [480Gbps x 15 + 550Gbps ] x 2 (full duplex).
Please correct me if I was wrong.
Thanks in advance.
Hello Tian,
Wasn't good example when I mentioned the F2 module, let's forget the linecards itself for a moment.
Considering the Nexus 7018 for the calculation, excluding the 2 supervisors, we got 16 rooms for modules.
Five fabric2 today can delivery 550Gbps for module. Then: 550Gbps x 16 = 8.8Tbps x 2 (full-duplex) = 17.6Tbps.
The throughput the swicth is calculated by the capacity to forward packets to the modules, no matter whether we are using modules M1, F1, F2, F3, F4, F17... . the total capacity the switch will be the same.
Today we don't have avaliable one module that can delivery 550Gbps to the fabrics, but the fabrics is already there and can process more than is requested today by the F2 linecard in the Nexus 7000.
Take a look to Fabric2 avaliable for Nexus 7700. Just because of the fabric, the swicth throughput capacity increased up to 83Tbps. We still don't have module to get there, either applications to push that.
I answered your question?
Just curious, why you pointed out this questions?
Hello Richard,
Thanks for your reply. My query is partially answered now.
Just one thing to confirm, does Fabric Switch provide 550Gbps BW for each I/O module concurrently or 550Gbps is shared by those 16 modules in a time-division way? I think this is the root cause of my query.
BTW, why I raise this query? -- I am recently involved in a DataCenter rollout project which drives me to begin self-learning of Cisco Nexus 7K/5K/2K Switches. I was confused when I came accross this Capacity parameters in the data sheet. So I just want to get to the bottom and do not want any confusion uncleared along with my Nexus trip.
Thanks in advance.
Hello Tian,
Yes, The switch can delivery 550Gbps per module concurrently, with 5 fabrics installed.
There is a pretty good document about it at Cisco Live 365.
BRKARC-3470 Nexus 7000 switch architecture (2013 Orlando).
Hello Richard,
Thanks a lot for your help. My query is full answered now.
