09-01-2011 06:42 AM
I'm not sure this relationship is as easy as it sounds. I have a 2248TP connecting on uplinks 3&4 to two ports (25&26) of a Nexus 2010 N7K-M132XP-12 card. I have followed the steps on CCO (install feature-set, activate feature-set, port-channel and interface config.) to the letter. I have also made sure that my transceiver is supported, when in fact, the transceiver used to be plugged into an N5K and worked beautifully. But I still get the error: "Configuration does not match the port capability" when I try to do the command "switchport mode fex-fabric" on the individual ports. But what's worse, It has gotten the fex serial number and type, but refuses to bring it on-line.
09-01-2011 09:41 AM
Can you post the port config (25 and 26) and the port-channel?
jerry
09-01-2011 10:11 AM
fex 101
pinning max-links 1
description "FEX0101"
interface port-channel101
switchport
fex associate 101
interface Ethernet2/25
no cdp enable
switchport
fex associate 101
channel-group 101
no shutdown
interface Ethernet2/26
no cdp enable
switchport
fex associate 101
channel-group 101
no shutdown
09-01-2011 10:24 AM
Hm... Interesting, can you post the output of the following:
show interface e2/25 cap
show version mod 2 epld
jerry
09-01-2011 11:30 AM
Chassis1(config)# sh ver mod 2 epld
EPLD Device Version
Power Manager 4.006
IO 1.014
Forwarding Engine 1.006
FE Bridge(1) 186.003
FE Bridge(2) 186.003
Linksec Engine(1) 1.008
Linksec Engine(2) 1.008
Linksec Engine(3) 1.008
Linksec Engine(4) 1.008
Linksec Engine(5) 1.008
Linksec Engine(6) 1.008
Linksec Engine(7) 1.008
Linksec Engine(8) 1.008
Chassis1(config)# sh int e 2/25 cap
Ethernet2/25
Model: N7K-M132XP-12
Type (SFP capable): 10Gbase-(unknown)
Speed: 10000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated/shared
QOS scheduling: rx-(8q2t),tx-(1p7q4t)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
Link Debounce: yes
Link Debounce Time: yes
MDIX: no
Pvlan Trunk capable: no
Port Group Members: 25,27,29,31
TDR capable: no
FabricPath capable: no
Port mode: Routed,Switched
FEX Fabric: no
dot1Q-tunnel mode: yes
EPLD Device Version
Power Manager 4.006
IO 1.014
Ethernet2/25
Speed: 10000
Duplex: full
Channel: yes
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
Link Debounce: yes
MDIX: no
TDR capable: no
FEX Fabric: no
09-01-2011 11:47 AM
Okay, I see the problem.
Ethernet2/25
FEX Fabric: no
FEX Fabric under the port capabilities said it is not supported. And according from the EPLD version, you are not running the minimum EPLD version to support FEX:
Please see the following link on how to install EPLD. Also, installing EPLD is discrupted because it will reload a LC:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/epld/epld_rn_5.1.html
HTH,
jerry
