Nexus 5010 management port - single or dual?
oahookins
Hi, I have a couple of 5010 Nexus switches. There are two physical ports on the front next to the L1 and L2 ports, but in the console I can only see mgmt0 and the device on the other end of the cables doesn't see a link on the second port. Do these devices actually support both management ports? The documentation is fairly sparse on this area.
Lucien Avramov
Level 10
Level 10
Only mgmt0 port (1 port) is supported for management on the Nexus 5000.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
