nexus 5548 layer3 features
ChenJianhang Chen
Community Member
Hi !
does anyone knows would the layer 3 daughter card on a nexus 5548up would support -
IP SLA
I need to use this feature to work with policy based routing.
Thanks!
Mark Malone
Just checked some of my lab 5548s which have N55-D160L3 installed for L3 , i dont see any  feature for ip sla to be enabled
Mod Ports Module-Type                         Model                  Status
1   32    O2 32X10GE/Modular Universal Platfo N5K-C5548UP-SUP        active *
3   0     O2 Daughter Card with L3 ASIC       N55-D160L3             ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    7.0(6)N1(1)     1.0     --
3    7.0(6)N1(1)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    547f.eed1.7708 to 547f.eed1.7727         FOC163550AG
3    0000.0000.0000 to 0000.0000.000f         FOC16347AN2
06# sh feature | i sla
06# sh feature
Feature Name          Instance  State
Flexlink              1         disabled
amt                   1         disabled
bfd                   1         enabled
bfd_app               1         enabled
bgp                   1         disabled
bulkstat              1         disabled
cable-management      1         disabled
cts                   1         disabled
dhcp                  1         disabled
dot1x                 1         disabled
eigrp                 1         enabled
eigrp                 2         enabled (not-running)
eigrp                 3         enabled (not-running)
eigrp                 4         enabled (not-running)
eth_port_sec          1         disabled
evmed                 1         disabled
fabric-access         1         disabled
fabric_mcast          1         disabled
fcoe                  1         disabled
fcoe-npv              1         disabled
fex                   1         enabled
glbp                  1         disabled
hsrp_engine           1         enabled
http-server           1         disabled
interface-vlan        1         enabled
isis                  1         disabled
isis                  2         disabled
isis                  3         disabled
isis                  4         disabled
lacp                  1         enabled
ldap                  1         disabled
lldp                  1         enabled
msdp                  1         disabled
nat                   1         disabled
netflow               1         disabled
oim                   1         disabled
onep                  1         disabled
ospf                  1         disabled
ospf                  2         disabled
ospf                  3         disabled
ospf                  4         disabled
ospfv3                1         disabled
ospfv3                2         disabled
ospfv3                3         disabled
ospfv3                4         disabled
pbr                   1         disabled
pim                   1         disabled
pim6                  1         disabled
poe                   1         disabled
pong                  1         disabled
private-vlan          1         disabled
privilege             1         disabled
ptp                   1         disabled
rip                   1         disabled
rip                   2         disabled
rip                   3         disabled
rip                   4         disabled
scpServer             1         enabled
sftpServer            1         disabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         disabled
udld                  1         enabled
vem                   1         disabled
vnseg_vlan            1         disabled
vpc                   1         enabled
vrrp                  1         disabled
vtp                   1         disabled
wccp                  1         disabled
