Nexus 7000: How many VRF
HI,
how many VRF are supported in NX-OS 5.X
3 Cisco Dokuments tell me another Thing.
1. 1000 overall
     250 each VDC
2. 994 each VDC
3. 8000
Can some give me an answer ?
Philipp
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/VMDC/2.0/design_guide/design.pdf
Page 2-25, Table 2-4, it clearly stated that it supports 1000 per-system and 250 per VDC.
2.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/virtual_device_context/configuration/guide/vdc_templates.html
Table 2-1 is the number of resources you can allocated to the VDC, not number of VRFs you can run (I know this is confusing). If you look at Table 2-2, it is the default resource where VRF is configured to 1000 which match what I told you. Let me give you a quick example, you can try to configure all 4000+ VLANs, but it doesn't mean system will not run out of memory and accept it.
3.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/unicast/configuration/guide/l3_limits.html
Table B-1, the 1000 VRF is there and it is correct. (994 is based on 1 management vrf per VDC. The other 2 reserve, I am not 100% sure, I need to do research).
My previous answer is not based on all these links. I got it from the internal BU page.
jerry
6 Replies 6
Reza Sharifi
The default value is 16.  The default maximum value is 8192.  The range is from 16 to 8192.
So the maximum number of supported vrf is 8192
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/virtual_device_context/configuration/guide/vdc_nx-os.pdf
Reza
The answer is 1.
1000 VRF in the system, 250 per VDC if you are using all 4 VDCs - This is for NXOS after 5.0.2 or above.
Pre 4.2.1, it is 800 per system and 200 per VDC.
HTH,
jerry
1.
2.
3.
jerry
Jerry,
Thanks for clarifying and providing further info (+5)
Indeed, this is very confusing
Reza
I know Reza. If I don't have the internal page I will not be this sure.
jerry
